Aston Martin’s 1,064-HP Valhalla Spider Can Do 217 MPH With the Roof Off
The open-top hybrid keeps the coupe’s outrageous performance—and gives American buyers a different roof arrangement.
There’s removing the roof from a supercar, and then there’s making sure the resulting hole doesn’t interfere with its ability to do 217 mph. Aston Martin says the new Valhalla Spider manages both. The company’s fastest open-cockpit car retains the coupe’s electronically limited top speed, even with nothing between its occupants and the sky.
That’s the headline. The more interesting story is how much engineering went into preserving it—and how little additional weight the conversion reportedly brings.
Underneath, the familiar Valhalla hardware remains: a twin-turbocharged 4.0-liter flat-plane-crank V-8, three electric motors, and an eight-speed dual-clutch transmission. Combined output is approximately 1,064 hp and 811 lb-ft of torque. Those figures correspond to Aston’s European ratings of 1,079 PS and 1,100 Nm; American buyers aren’t getting shortchanged on horsepower.
The V-8 supplies approximately 817 hp on its own. Two electric motors power the front axle and provide torque vectoring, while a third motor works alongside the transmission to assist the engine at the rear. There’s no mechanical connection between the axles. Instead, the electronics coordinate the two ends while also managing the suspension, braking, steering, and active aerodynamics.
Aston lists a claimed 0–62-mph time of 2.5 seconds. That’s a manufacturer figure, and it shouldn’t be confused with a tested 0–60 result. Either way, the Spider clearly hasn’t been positioned as the laid-back member of the family.
The Roof Situation Requires Some Explanation
This isn’t a convertible with a button that makes the roof disappear at a stoplight. The Valhalla Spider uses removable roof panels, and the configuration matters.
Aston’s global announcement describes a stowable fabric roof as standard, with a carbon-fiber hardtop available optionally. Fit the fabric roof, and maximum speed drops to 124 mph. Install the carbon panel—or remove the roof entirely—and the full 217 mph is available.
There’s a relevant distinction for American shoppers: Road & Track reports that U.S. cars will receive the carbon-fiber roof instead of the fabric item offered elsewhere. Aston’s own specifications note that roof equipment varies by market.
The clever part is the airflow management. A clip-in wind deflector directs air over the occupants while helping feed the intake snorkel behind them. That snorkel has been reshaped and raised approximately 1.4 inches to accommodate the Spider’s different airflow.
When it isn’t needed, the deflector folds into three sections and fits into new storage compartments in the sills. It’s a small concession to practicality in a car whose primary packaging concern is accommodating a hybrid powertrain and the air it needs.
Keeping the Aero Working
Removing a roof changes more than the occupants’ exposure to sunlight. It alters the air reaching the rear of the car, which matters when movable aerodynamic surfaces are responsible for managing grip and high-speed balance.
Aston has recalibrated both the active aero and stability-control systems for roof-on and roof-off operation. The front and rear aerodynamic devices adjust the distribution of downforce, while the underbody contributes its own substantial share.
The official specifications list more than 1,323 pounds of downforce at 150 mph in Race mode. There’s an important qualification: The launch announcement’s maximum-downforce claim applies with the roof fitted. Matching the coupe’s top speed with the roof removed doesn’t automatically mean matching every roof-on aerodynamic figure.
The structure remains centered on a carbon-fiber passenger cell developed with Aston Martin Performance Technologies, the consulting arm of the company’s Formula 1 team. That provides a promising foundation for the conversion, although structural rigidity and steering feel ultimately need to be assessed from the driver’s seat.
Here’s another encouraging number: PistonHeads reports a weight increase of just 55 pounds over the coupe, with a quoted dry weight of approximately 3,704 pounds when equipped with lightweight components. Dry weight excludes operating fluids and isn’t directly comparable with the curb weights used in most American road tests. Still, the reported increase is modest.
A Little Easier to Live With
The Spider also introduces a standard carbon-fiber Touring seat intended to improve comfort and make getting in and out easier. Buyers who prefer the coupe’s original seat can specify it at no additional cost.
The upward-opening dihedral doors remain, but Aston has revised their operating mechanism and adopted frameless glass. A change to the upper edge of the windows is intended to improve access with the roof installed. These are useful details in a car that needs to be enjoyable before the engine even starts.
Price remains unannounced. For context, Car and Driver lists the fixed-roof Valhalla at $1,051,700, putting any discussion of the Spider’s eventual premium firmly into seven-figure territory.
The Valhalla Spider is scheduled to make its public debut at the Wynn Concours in Las Vegas, with customer deliveries beginning in the third quarter of 2027.
On paper, Aston has made a compelling trade: a reportedly small weight increase, unchanged power, and access to the same extraordinary top speed with the roof removed. The real test will happen well below 217 mph. If the Spider preserves the coupe’s precision while making its V-8 feel that much closer, the missing roof could become the best reason to buy one.
