The Aston Martin V12 Vantage (RS) will debut early next year before going on sale in very limited numbers
Spyshot
Spyshot
Expected to be one of Aston Martin’s final V12 models, if not the very last hurrah due to ever-stringent emission regulations, the twelve-cylinder sports car will be offered exclusively with the ZF 8HP eight-speed auto.
As opposed to the 8HP75 in the V8 Vantage, we’re most likely dealing with the 8HP95 of the DBS Superleggera. The main difference between these boxes comes in the guise of torque rating. More specifically, the higher-numbered version can take up to 900 Nm (664 pound-feet) for gasoline applications and 1,000 Nm (738 pound-feet) for turbo diesel applications.
Rumored to be revealed in the first half of 2022, the V12 Vantage is also rumored to be limited to 300 units although it remains to be seen if the hearsay is correct. As for the fury hiding under the hood, the safest guesstimate would be V12 Speedster-matching horsepower and torque.
A limited-run special edition, the V12 Speedster cranks out a glorious 690 horsepower and 555 pound-feet (753 Nm) from its AE31 V12 colossus.
Source: https://www.autoevolution.com
