Source: https://www.instagram.com/the_r_rated/?utm_source=ig_embed
Source: 最新記事 - 自動車情報誌「ベストカー」
5 Door Liftback Teaser
Rendering…
The front end will be styled with other new Acura models, with the most interesting element being the Integra name stamped under the left headlight.
The rear will echo the last generation of the 2001 Integra / RSX thanks to horizontally elongated headlights (one of which will also be the model name) and a trunk lid connector with a recess for the opening handle in the center that unites them. And it is already clear that the loading height of the trunk will be very high, since the door will open together with the rear window, as befits a liftback.
Acura Integra Type R or Type S
