The 2024 Buick Envision will arrive as the fourth model year for the current second-generation crossover, introducing a model refresh that will include new styling and a revised interior. Now, the refreshed 2024 Buick Envision has been caught testing in prototype form. Up front, the nose of the refreshed 2024 Buick Envision is clearly in line with styling cues seen on the 2023 Buick Envista, with long, thin, angular lighting signatures that draw up from the fascia and into the front fenders. Additional forward lighting elements can be seen below the lighting signatures, mounted in a vertical layout in the corners of the bumper. Note that the lighting elements seen here are placeholder pieces.
Meanwhile, the fascia appears to be rounded and smooth with the exception of a hard angular line separating the hood line from the primary intake. The intake looks to emphasize the horizontal plane in terms of layout.
In the corners, we spot some large alloy wheels with a silver finish and broad multi-spoke design. A set of silver roof rails are seen up top.
The rear end is characterized by a set of large rear tail lamps, which may look a bit silly on this prototype – however, these are just placeholder units added in anticipation of revised tail lamps set to debut with the 2024-model-year refresh. The muffler and exhaust are also neatly hidden.
Finally, the 2024 Buick Envision cabin space is expected to boast a larger infotainment screen. Unfortunately, images of the new cabin are currently unavailable.
Source:https://driving.ca/
