2025 Audi Q3
The Audi Q3, now in its third and last generation with combustion engines, has been spotted conducting testing on German streets. Our surprise was that, in addition to the final lighting, the small crossover appeared to already have all of the production body panels in place. The BMW X1 competitor has split headlights that follow design trends. The upper strip houses the DRLs and turn signals, while the rectangular notch in the bumper houses the low and high beams.
Similarly, the Audi Q3 from 2025 looks to have a light bar connecting the taillights, with a strip that is positioned above the license plate and is around the same length. We discover more details about the prototype as we examine it more closely. For instance, a charging port on the driver’s side front fender indicates the test car had a plug-in hybrid powertrain.
I might be dealing with a lower trim level because the exhaust tip is tucked away behind the bumper. Due to the addition of extra plastic to the space separating the grille from the lower air intake, Audi’s corporate Singleframe grille is now slightly narrower. Overall, it appears that the Q3 will take styling ideas from Ingolstadt’s electric vehicles, notably the Q4 E-Tron.
Technically, the new one Q3 building up the “MQB Evo” architecture one last time could be the third just presented VW Tiguan emulate. The new one should run off the assembly line Q3 together with the Cupra branch in Terramar, Hungary, could therefore also be the electrified drive of the Spanish one SUVs take over.
Up to 272 hp in the new Q3
The Spaniard will be available with a new generation of plug-in hybrid drives and various internal combustion engines. Its electrical range should be around 100 WLTP kilometers, the system output should be between 204 and 272 PS lie.
Basically, the engine range should start with electrified drives, which in addition to possible plug-in technology also include mild hybrid systems with a 48-volt electrical system. It is worth taking a look at the new one here Tiguan, which optionally with 1.5 eTSI with 130 or 150 PS is coming. The larger petrol engines with a displacement of two liters perform in 204 and 265 PS and both should come with all-wheel drive.
The new Q3 will come with a radical redesign of its front fascia compared to the outgoing model. The Singleframe octagonal radiator grille will be slightly smaller since there will be more plastic around the area separating the grille from the lower air intake. The panel will also feature a new pattern with overlapping U-shaped motifs. This won’t be the largest change though, as two big rectangular headlights will sit on the two corners of the bumper acting as the low and high beams.
While not seen on these renderings, the rear end is expected to receive a more conservative redesign. The taillights will be slimmer but will retain their basic shapes, as seen in the spy photos from September. To a certain extent, the rear lights will be similar in form to the clusters seen on the Q4 E-Tron, though there won’t be an LED strip connecting them through the boot – at least we can’t see one for now.
2024 Audi Q3 renderings
Audi Q3 2025 reveals details
The Audi Q3 has been spotted in winter testing. The compact SUV, set to arrive in 2025, is part of the Volkswagen group and has been tested in Sweden.
The prototypes show a thin band on the hood with Matrix LED technology, integrated turn signals, and low and high beam headlights. The Q3 2023 has a flatter design, more familiar and less bulky, following its older brother.
Inside, the dashboard features a steeper center console with a touch screen for the infotainment system.
The Q3 will be available in diesel and gasoline with front-wheel drive and quattro all-wheel drive, all with seven-speed S-tronic dual-clutch automatic transmission.
The PHEV model will have a powerful battery that can last up to 100 kilometers. The Audi Q3 will also offer plug-in hybrid versions.
Audi comes with the third generation of the Q3.
  • The last Q3 with internal combustion engines
  • As a plug-in, but not as EV
  • Also as a Sportback
Audi Q3 (Illustration: Larson)
2025 Audi Q3 prototype crashes into ditch
2026 Audi Q3 spy shots
Source: www.motorauthority.com
Q3 Sportback
The new Audi Q3 has recently been spotted near Denver, Colorado, USA, according to a recent post (posted October 1st, 2025) on Reddit. Source link is below these pictures.
Source: https://www.reddit.com/r/Audi/comments/1nvff5f/spotted_these_audi_test_cars_near_denver/
The New Audi Q3 Spotted in China
