Zeekr 007 to reportedly to get wagon version as ties between Swedish and Chinese brands deepen Zeekr is also introducing a model codenamed CC1E after the Zeekr 007 and CX1E. which will be a touring version of the Zeekr 007, AutoPix said, adding that the model has just been projected.
Zeekr 007 revealed 100-kWh battery pack for 870 km range.
- RWD, 310 kW (415 hp), 75.6-kWh LFP battery from Quzhou Jidian EV Tech, 688 km range
- RWD, 310 kW (415 hp), 100-kWh ternary NMC battery from CATL-Geely JV, 870 km range
- 4WD, 475 kW (636 hp), 100-kWh ternary NMC battery from CATL-Geely JV, 723/770 km range
The fourth model of Zeekr, which goes by the internal development code “CS1E,” may also adopt the new system of trade names made up of letters and be referred to as Zeekr S.
It will utilize the same electric motors and batteries because it will also be built on Geely’s ground-breaking “SEA” platform for electric vehicles.
The Chinese Ministry of Industry normally leaks relevant information about the model, but there are very little specifics available at this time.
However, it is known that the model will be unveiled before the end of the year. Something that shouldn’t come as a surprise given the advanced stage of development, which would indicate a one-year debut on the continent of Europe.
