The 2026 Ford Bronco EV boldly blends the timeless ruggedness of the Bronco with cutting-edge electric performance. Designed to compete with off-road hybrids and EVs like the Jeep Wrangler 4xe and the upcoming Scout Traveler, the Bronco EV keeps its trail-ready DNA while embracing a cleaner, quieter future.
Design: Iconic Bronco Looks with a Modern EV Twist
Visually, the Bronco EV stays true to its roots—square wheel arches, a boxy silhouette, swing-out tailgate, and a rear-mounted spare tire. However, the EV updates are clear: a sleeker front fascia, hidden door handles, flush body panels, and the absence of exhaust pipes signal its all-electric nature.
Powertrain Options
Ford will offer two versions:
- Full Battery Electric Vehicle (BEV)
- Estimated output: ~271 hp (202 kW)
- Powered by a ~105 kWh LFP battery
- Zero tailpipe emissions with instant torque
- Extended-Range Electric Vehicle (EREV)
- Estimated output: ~241 hp (180 kW)
- Uses a ~43.7 kWh battery paired with a 1.5L turbocharged petrol engine acting solely as a generator
- Allows several dozen miles of pure electric driving before the engine activates
Chassis & Off-Road Capabilities
- Length: ~4,811 mm (189.4 in)
- Wheelbase: ~2,670 mm (105.1 in)
- Ground Clearance: Up to 333 mm (13.1 in)
- Water Fording: Up to 940 mm (37 in)
- Wheel Options: Rumored 18- to 35-inch sizes
- Towing Capacity: Up to 2,041 kg (4,500 lb) depending on trim
Despite its EV transition, the Bronco still means business off-road—with familiar features like Bronco bumpers, rock rails, and a rear kick-out for approach angles.
Interior & Technology
No full interior images yet, but sources suggest:
- Ford’s latest SYNC system on a digital dashboard
- Off-road telemetry and EV energy flow displays
- Over-the-air (OTA) updates
- Integrated adventure features, such as trailer readouts and trip planning for electric terrain driving
Expect a digital, connected cabin that complements the Bronco’s adventure-ready spirit.
Competitive Landscape
With the Jeep Wrangler 4xe carving out early dominance in electrified off-roading, Ford’s timing is calculated. The Bronco EV keeps the open-air, door-off freedom enthusiasts love but swaps the engine growl for silent power and torque. It’s still a Bronco—just unplugged.
Pricing
- Entry-level BEV model: Estimated starting around $55,000
- EREV versions: Expected to start slightly lower
- High-end dual-motor off-road trims: Could exceed $70,000+
Conclusion
The 2026 Ford Bronco EV isn’t just an electrified SUV—it’s a modern trailblazer that stays true to its roots while embracing tomorrow’s technology. Whether you’re a weekend off-roader or an eco-conscious adventurer, this electrified Bronco is built to climb quietly but boldly.
