2027 Mercedes-AMG GT PRO Track
Referred to as Track, said version is clearly derived from the GT 63 PRO 4MATIC+ from a visual standpoint. Building on this incredibly capable sportster, the mysterious newcomer proudly boasts a massive rear wing and carbon-ceramic brakes framed by forged wheels that are mounted with Michelin hi-po rubber, This development prototype also builds on the series-production GT 63 PRO 4MATIC+ with canards for the front bumper. A more prominent spoiler can also be seen, and chances are that AMG has also worked its magic on the underbody aero for a little bit more downforce, To extract maximum performance, AMG may also consider offering a roll cage with a similar design to what you can see in these spy photos. A roll cage doesn’t make a performance vehicle faster by itself, but does reduce flex in high-load corners by stiffening the chassis, Less flex results in more precise handling, consistent suspension response, and improved tire contact with the road, allowing the driver to carry more speed through corners. The downsides to such a roll cage are the added weight and the harder ingress and egress.
Mercedes-AMG GT PRO with some aero upgrades spotted!
