Hyundai Motor’s IONIQ 5 N Debuts at Goodwood Festival of Speed
Hyundai Motor Company’s IONIQ 5 N – N brand’s first high-performance, all-electric model – made its world premiere today at the Goodwood Festival of Speed in West Sussex, England. IONIQ 5 N represents N brand’s electrification future and a new way for high-performance enthusiasts to electrify their passion for driving on road and track.
The new vehicle represents Hyundai’s long-standing legacy of offering high-quality mobility alongside driver-focused N models. N brand made a comeback to WRC in 2014 and its subsequent success with multiple world championships infused Hyundai with a winning DNA, reflected in the N high-performance models. This momentum carries forward with electrification, as the award-winning E-GMP-based IONIQ 5 provides the perfect foundation to create N’s first high-performance EV.
IONIQ 5 N establishes Hyundai N as the technology powerhouse within Hyundai Motor and spearheads advanced technologies to be shared with all Hyundai EVs with the strategic goal of increasing Hyundai’s overall competitiveness. IONIQ 5 N represents the first step to this strategic shift with additional electric N models to follow.
Dual-motor AWD with rally-inspired handling supports Corner Rascal capabilities
IONIQ 5 N’s Corner Rascal capabilities begin with enhancements to the body-in-white (BIW) structure with 42 additional welding points and 2.1 meters of additional adhesives. The motor and battery mounting are reinforced while front and rear subframes are enhanced for lateral rigidity. World Rally Championship-inspired integrated drive axles (IDA) are applied both front and rear and reinforced to endure stronger electric motor torque while reducing unsprung mass together with the 21-inch forged aluminum wheels.
To enhance steering response and feedback, IONIQ 5 N’s steering column has been strengthened for improved rigidity. Additionally, the vehicle features a specially tuned N R-MDPS (Rack-Mounted Motor-Driven Power Steering) system with a higher steering ratio and enhanced torque feedback. These enhancements result in a more direct and communicative steering experience that will instill greater confidence in drivers.
N Pedal was developed as a solution to address the inherent weight and size of EVs while aiming to achieve the responsive handling characteristics seen in Hyundai’s championship-winning i20 N WRCs. This intelligent software function, found in IONIQ 5 N, is designed to provide instant turn-in behavior and enhanced throttle sensitivity. Drawing on similar technology used in i-Pedal’s regenerative braking system, N Pedal prioritizes fast and exhilarating cornering over energy efficiency. By utilizing decelerative force, an aggressive weight transfer is created, resulting in sharper corner entry.
N Drift Optimizer helps to maintain the drift angle by balancing multiple vehicle controls responding to real-time inputs. The integrated Torque Kick Drift function allows the driver to simulate the clutch kick action of rear-wheel-driven ICE vehicles for driving scenarios that require more immediate drift initiation. This is a result of sophisticated electronic control technology.
N Torque Distribution provides fully variable front and rear torque distribution that can be adjusted to 11 levels. The e-LSD (electronic limited slip differential) at the rear axle optimizes cornering performance and control. Additional wheel sensors and broader damping capacity with increased damper size widens the performance range of the electronically controlled suspension.
Improved PE system, enhanced battery cooling and N Brake Regen bolster Racetrack Capability
This powerful EV benefits from several technical improvements. Its electric motors spin up to 21,000 RPM providing 478 kW / 650 PS with N Grin Boost engaged. This is a result of the two-stage inverter with increased energy efficiency for stronger power output from the new 84 kWh battery.
Several exclusive features aid track performance. N Grin Boost maximizes acceleration by a power increment of 10 seconds and N Launch Control provides three different traction levels for the fastest possible start, allowing drivers to launch their vehicle like a professional race car. Track SOC (state-of-charge) automatically calculates battery consumption per lap.
IONIQ 5 N sets a new benchmark for thermal management in severe racetrack conditions. Compared to its competitors, IONIQ 5 N boasts a higher resistance to heat induced power degradation – loss of maximum power due to overheating.
The enhanced battery thermal management system, with increased cooling area, better motor oil cooler and battery chiller. The independent radiators for the battery and motor maximize IONIQ 5 N’s resistance to performance degradation before and during intense track driving.
Before driving, the driver can utilize N Battery Pre-conditioning to optimize the battery cells to the most power-efficient temperature by choosing between ‘Drag’ mode for a short burst of full power or ‘Track’ mode that optimizes the lowest possible battery temperature for more laps.
N Race feature further optimizes the EV’s endurance on the circuit, giving drivers more direct control over the car’s energy usage. N Race applies a motorsport-derived approach to maximizing resources for the fastest possible times. While this type of setting change would normally require a team of mechanics and equipment, IONIQ 5 N offers it at the convenience of a few button presses.
With N Race, drivers are given the strategic choice to prioritize ‘Endurance’ or ‘Sprint.’ ‘Endurance’ maximizes range on the racetrack. This is achieved by limiting the peak power, which results in a slower build-up of temperature. Comparatively, ‘Sprint’ prioritizes power and provides shorter bursts of full energy. This will help drivers accurately manage their energy strategy and create an ideal performance window to achieve their driving performance targets.
IONIQ 5 N boasts N-tuned brakes, which represent Hyundai’s most powerful braking system. It features 400-mm diameter front discs with four-piston monobloc calipers and 360-mm rear discs. These brakes are constructed with new lightweight materials and optimized airflow for improved cooling efficiency. In addition, the regenerative (regen) braking system typically used for enhanced efficiency has been reinterpreted in IONIQ 5 N to enhance braking performance. It serves as the primary source of brake force, while the mechanical brakes supplement additional braking force when required, ensuring enhanced endurance on the track.
To address the harsh braking demands of the Nürburgring Nordschleife, Hyundai N engineers designed N Brake Regen, an N-specific region braking system developed specifically for IONIQ 5 N. It offers up to a maximum of 0.6 G decelerative force – an industry leading figure – through N Brake Regen alone and remains engaged under ABS activation with a maximum of 0.2 G. The risk of brake fade due to the EV’s relative heaviness is minimized by maximizing regen braking power, which results in lower brake force applied to the mechanical brakes.
The seamless blending between the N Brake Regen and hydraulic brakes creates a smooth transition that is imperceptible to the driver. Moreover, left foot braking allows the brake and accelerator pedal to work at the same time when driving on the track.
State-of-the-art technology delivers shift feeling and emotional fun in an Everyday Sportscar
As an everyday sportscar, IONIQ 5 N delivers an engaging shift feeling and emotional driving through the integrated N e-shift and N Active Sound +. N e-shift provides a sense of control over power delivery and shift feeling while N Active Sound + works collectively to deliver not only a futuristic EV sound but also ICE-like engine and exhaust sounds that provide a more engaging experience behind the wheel. Together, they enhance the fun and joy of driving by simulating the jolt feel and sound of an ICE vehicle.
Many performance enthusiasts have been outspoken about the lack of driver feedback behind the wheel of many EVs. That’s why Hyundai N engineers developed the N e-shift and N Active Sound + functions to deliver greater driver feedback and therefore more precise driver control of IONIQ 5 N’s dynamic driving. The unique emphasis on precise power control differentiates N’s approach to EV sound from past applications.
N e-shift simulates the eight-speed dual-clutch transmission (DCT) of internal combustion engine (ICE) N cars. It simulates a gearshift by controlling motor torque output and simulates the jolt feeling between shifts. As a result, it provides a more precise, interactive driving experience that feels closer to ICEs than previous EVs.
N Active Sound+ is paired with N e-shift to enhance the driving experience of EVs by creating a more engaging and exciting sensory experience for the driver. It incorporates a 10-speaker system (eight internal, two external) that offers three distinct sound themes. The ‘Ignition’ theme simulates the sound of N’s 2.0T engines and ‘Evolution’ provides a signature high-performance sound inspired by the RN22e. The ‘Supersonic’ theme is a unique concept inspired by twin-engine fighter jets, featuring variable volume during cornering. The objective of N Active Sound+ is to provide drivers with an acoustic reference to gauge the power being utilized.
IONIQ 5 N also is equipped with N Road Sense, which automatically recommends the activation of N Mode when double-curved road signs are detected, enabling drivers to enjoy every second of their drive to the fullest (EU only).
Like the standard IONIQ 5, its N variant is equipped with Vehicle-to-Load (V2L), which allows the driver to use the stored energy from the EV’s high-voltage battery to recharge devices, such as an e-bike, electrical camping equipment or domestic appliances – even when the vehicle is turned off.
Download
Performance-enhancing design elements to inspire passionate driving
IONIQ 5 N’s exterior adds many performance-enhancing design elements, such as contrasting black trim parts and a wing-type rear spoiler, which emphasize the sporty aspects of the standard model and maximize its circuit driving potential.
The N model further distinguishes itself from the standard IONIQ 5 with a change of proportions. It is 20 mm lower overall, 50 mm wider at the bottom to accommodate wider tires and 80 mm longer due to the more prominent diffuser.
IONIQ 5 N’s interior neatly conveys the N family look with the application of N-branded elements, including the steering wheel, seats, door scuff panels and metal pedals, etc., and is optimized for track driving.
Download
The newly designed N steering wheel prominently features the N logo for the first time, flanked by N buttons that set the desired drive mode, arranged to suit the driver’s preference. Driving modes can be customized and matched to each button in various combinations to maximize IONIQ 5 N’s fun driving spirit. N Grin Boost button positioned at 3 o’clock allows instant and intuitive access to maximize acceleration and driving fun.
Download
Paddles are optimally positioned at driver’s fingertips to engage N e-shift and N Pedal features.
IONIQ 5 N’s center console is optimized for track driving with knee pads and shin support as well as a sliding armrest. An extension to the lower part of the console enhances rigidity to further support sport driving. For everyday use, it also offers a C-type USB, wireless charger and cupholders.
The N seats have reinforced bolsters, so that even if strong lateral acceleration occurs during sharp cornering, it firmly supports the upper and lower body to maintain a stable driving posture at all times. The N bucket seats are positioned about 20 mm lower compared to the basic specification, designed for customers who pursue high-performance drivability. N emblems are arranged front and rear of the seat with welcome lighting at front. The two-toned design theme of the bucket seats carries over to the rear.
Download
Due to the nature of N driving, IONIQ 5 N’s pedals are optimized for foot contact in track driving scenarios that involve oversteer, drifting and power slides, reducing the risk of foot slippage in two-foot driving. The footrest is optimized to maintain a stable driving posture at all times, including strong deceleration moments.
The new checker flag theme – a track-inspired riff on IONIQ 5’s iconic parametric pixels – can be found on the door scuff panels metal pedals and footrest, representing N Brand’s motorsport spirit.
Much like the standard IONIQ 5, sustainable materials are applied throughout IONIQ 5 N, including recyclable paperette door decorative garnish, BIO PET yarn from sugarcane, recycled PET yarn from recycled PET bottles, BIO TPO from sugarcane and eco processed leather. IONIQ 5 N also adds recycled tire pigment paint and recycled poly Alcantara seat cover cloth.
Specifications
Motor output
  • Front: 166 kW / 226 PS
  • Rear: 282 kW / 383 PS
  • Total output: 448 kW / 609 PS
  • Boost output: 478 kW / 650 PS
    (Front: 175 kW, 238 PS / Rear: 303 kW, 412 PS)
Battery
Capacity: 84 kWh
Charging
  • Charge Speed: 350 kW
  • Charge time: 10% to 80% in 18 minutes
Dimension
  • Length: 4,715 mm
  • Width: 1,940 mm
  • Height: 1,585 mm
  • Wheelbase: 3,000 mm
Tires
Pirelli P-Zero 275/35R21
Braking system
  • Front: 4 piston 400 mm
  • Rear: 1 piston 360 mm
Regenerative braking
Deceleration: 0.6 G (0.2 G during ABS activation)
0 – 100 km/h
3.4 sec. (Boost)
Top speed
260 Km/h
Range
To be announced at regional market launch
Exterior colors
Performance Blue Matte, Performance Blue, Abyss Black Pearl, Cyber Gray Metallic, Ecotronic Gray Matte, Ecotronic Gray , Atlas White Matte, Atlas White, Gravity Gold Matte and Soultronic Orange Pearl
Interior color
Black with Performance Blue accents
