Xiaomi SU7 Ultra Extreme Could Be a 2,000+ HP Monster
Xiaomi appears to be preparing an even crazier version of the SU7 Ultra, potentially called the SU7 Ultra Extreme.
A camouflaged prototype has been spotted in China with some serious aero upgrades. The biggest giveaway is the massive swan-neck rear wing, which could feature DRS, along with a much larger rear diffuser. Up front, there are new aero elements and vented wheel arches designed to reduce front-end lift and improve stability at speed.
The prototype also gets new lightweight wheels, yellow fixed brake calipers and carbon-ceramic brakes, while carbon-fiber mirror caps and the roof-mounted LiDAR remain.
But the wildest rumor is the powertrain. Xiaomi is reportedly developing a new four-motor setup producing up to 2,054 hp, and this limited-run SU7 Ultra could be one of the first models to use it.
For comparison, the current SU7 Ultra already makes 1,548 hp from three motors, hits 100 km/h in a claimed 1.98 seconds excluding rollout, and can exceed 350 km/h.
If the 2,000+ hp figure is real, Xiaomi isn’t just upgrading the SU7 Ultra — it’s basically turning it into a road-going version of its track-focused prototype.
Source: autohome
Xiaomi’s SU7 Ultra Extreme is back at the Nürburgring with a huge twin-plane rear wing, a bigger front splitter, and a new diffuser. DRS is rumored, but nothing’s confirmed yet.
The regular Ultra already makes over 1,500 hp, so getting that power to work through the corners seems to be the focus now. There are even shots of the brakes glowing red.
Really curious what this thing can do on a full lap—and how close the production version will be to these test cars.
Source: www.autoevolution.com
